Leaking fluid
dave66
PostPosted: Wed Feb 25, 2009 8:13 am    Post subject: Leaking fluid Reply with quote
I need someones advice.........On a daily basis, I am finding drops of fluid underneath my motor. It is more of a oil/gas mixture. Where is it coming from? What is it? And what are some of the possible causes????? And lastly, what can I do to stop the leak????
Thanks
Bad Bug Two
PostPosted: Wed Feb 25, 2009 8:29 pm    Post subject: Reply with quote
Don't you realize that bugs don't leak.... they just mark their territory!
Laughing
Jeff Rogers
www.badbugracing.com
9.35 @ 145
dave66
PostPosted: Thu Feb 26, 2009 7:24 am    Post subject: Tes they do! Reply with quote
Laughing Aint that the truth!
PostPosted: Thu Feb 26, 2009 7:57 am    Post subject: Reply with quote
OK, seriously, if you think it is gas or part gas, DO NOT DRIVE IT!
1) the obvious fire hazard, 2) if the carb has been leaking into the engine to the point it has contaminated the oil, it will destroy the bearings.
Check the oil on the dipstick, if it's higher than it should be or it smells like fuel, you need to change the oil immediately.
Sometimes the float valve will let fuel run into the engine when it not running. Particularly if the front of the car is higher than the back. As to where it's leaking, just look for it. If your engine is so greasy that it looks oily everywhere, we're onto a different subject.
dave66
PostPosted: Thu Feb 26, 2009 9:04 am    Post subject: Greasy Reply with quote
Underneath the engine is completely gummed up with grease oil. What does that mean?
PostPosted: Thu Feb 26, 2009 11:03 am    Post subject: Reply with quote
You have a grease,oil leak from somewhere.
Possibilities:
Main seal
pushrod tube(s)
case
oil cooler
oil strainer plate
Transmision
pulley blow by excessive
Oil sender
Fuel pump
Gen stand
oil filler
Jugs
Valve covers
Oil Pump
Oh, definitely listen to what Onebadbug says. If you have gas leaking, you will eventually have a VERY bad day, if you have gas in your oil, that's another story as well.
PostPosted: Fri Feb 27, 2009 7:39 am    Post subject: Reply with quote
Hey, that's ONEBADBUG, all caps, cause I'm intense!
Cool
I don't mean to be a wiseass, but I didn't respond at first because asking why a bug leaks oil is like asking where a bear poops. There's too many possibilities. Maybe run over to Custom VW and ask him. I'm still not guite sure you're serious.
Mr Bs Bug N Buggy
PostPosted: Fri Feb 27, 2009 9:40 am    Post subject: Reply with quote
Cool
I read it when it first hit, I didn't respond for the same reason.... Wink
Besides the fact I thought it would take me an hour to type all the possibilities.... Shocked
Mr. B
Viper Dune Buggy
and some parts !!!
Dune Buggies are unequaled in "smiles per mile"
PostPosted: Fri Feb 27, 2009 9:52 pm    Post subject: Reply with quote
Sounds like you got yourself a Volkswagen
Bad Bug Two
PostPosted: Sat Feb 28, 2009 6:32 am    Post subject: Same here Reply with quote
That's why I also didn't make a real list.
The list of why they don't leak is shorter!
Laughing
The only bug that doesn't leak.... has no oil in it!
Shocked
Jeff Rogers
9.35 @ 145
shakajava
PostPosted: Mon Mar 16, 2009 7:46 pm    Post subject: Reply with quote
Thats so funny all mine leak as well. I think they will not leak when you replace all the engine gaskets. I know that worked with my old Volvos.
WAIT!! I don't think there are any engine gaskets with an aircooled. Do the heads have engine head gaskets??
69' Beetle CA Look 1500SP
71' Super 1600DP
