hard/no start in winter
PostPosted: Sun Dec 11, 2011 4:26 pm    Post subject: hard/no start in winter Reply with quote
my battery is new the motor is a 1600sp. i have to either jump start or (if i remember to) put the battery on the charger overnight. what have you guys done to overcome this?? would it help to insulate my battery in some way to keep it warmer?
hakunamatata
PostPosted: Mon Dec 12, 2011 8:06 pm    Post subject: Reply with quote
When you hop in and turn the key, what happens? Engine spins but no start? Engine spins slowly? No spin, but a click? Nothing but dash lights? Nothing at all?
19bay70
PostPosted: Tue Dec 13, 2011 10:51 am    Post subject: Reply with quote
I just keep a trickle charger on my battery and dont seem to have any issues starting my 1600 in bus
PostPosted: Tue Dec 13, 2011 4:46 pm    Post subject: Reply with quote
hop in and slow turn. then no turn.
if i have it on a charger/ or jump it then it fires up right away.
just thought someone has come up with a insulation idea.
i guess i'll tinker around with it and post my findings
hakunamatata
PostPosted: Tue Dec 13, 2011 5:14 pm    Post subject: Reply with quote
How are your cable connections? That would be the first thing I would check. Both the battery terminals, the starter terminal, the ignition switch terminal, the ground straps (yes, there are two) and the voltage regulator terminal. Clean, tight, and fresh looking. Wouldn't be a bad idea to have the battery load tested at your FLAPS, too. But it sounds like a connectivity issue to me. VW's generally start quite well when it's cold.
PostPosted: Tue Dec 13, 2011 10:06 pm    Post subject: hard/no start in winter Reply with quote
possible bad starter bushing, bad grounds, missing ground strap from pan to trans, loose cables
PostPosted: Tue Dec 13, 2011 10:19 pm    Post subject: Reply with quote
Starter bushing. I forgot about the starter bushing. Good point.
