Good starter for for my '71 running gear '64 Karmann Ghia
smithe
PostPosted: Mon May 11, 2009 11:22 am    Post subject: Good starter for for my '71 running gear '64 Karmann Ghia Reply with quote
Thanks.
PostPosted: Mon May 11, 2009 1:52 pm    Post subject: Reply with quote
You need to determine if it's 6 or 12 volt, it's most likely that the transmission was ground out to accept the 12v flwheel and starter. The bushing in the transmission is probably a special adapter bushing also. If you get a bus automatic trans starter, it doesn't require a bushing, it's like a normal car. It will say on the starter, but I don't know if you can see that in the car.
smithe
PostPosted: Mon May 11, 2009 3:07 pm    Post subject: Reply with quote
I will be under it later and double check, but it's a '71 pan, motor and tranny with '64 body on it so it should all be a 12volt.
PostPosted: Mon May 11, 2009 3:27 pm    Post subject: Reply with quote
You are welcome to try out some of the ones out back, on my starter jig.
PostPosted: Tue May 12, 2009 11:47 am    Post subject: Reply with quote
I have a 12v starter. The sol. is bad...but worked fine when bypassed. $5 and it is yours.
http://www.thesamba.com/vw/classifieds/detail.php?id=403667
