Shakey Slim
Posted: Sat Apr 26, 2008 1:31 pm Post subject: Help with small welding problem |
Ah Spring! Time to wrench on the bug!
I was out replacing the clutch cable this morning, and noticed that the cable tube has broken free of the front weld.
Does anyone here have a MIG welder and the time to tack this back on for me? There is an access panel already cut in the tunnel, so it should be a pretty easy job. I can tow the car anywhere (within reason!), I'm in Millwood. |
![](images/avatars/10097437785001e5dfe0c31.jpg)
Posted: Sat Apr 26, 2008 11:35 pm Post subject: |
I have a welder and I live in Millwood (between Big R and West Valley High), that should be an easy fix.
Call me 926-6843 or cell (808)634-7124 Dale |
Shakey Slim
Posted: Sun Apr 27, 2008 3:05 pm Post subject: |
Thanks Dale. Got it taken care of. You're just up the street from me!
It ended up not being a simple weld after all. It took some creative bracket making by Jim (jengle451) to solve that problem! |
Posted: Sun Apr 27, 2008 9:07 pm Post subject: |
Yes, I know what you mean, I did a couple of those and it can be quite a task. Well its good to know that you got it done and if you need help with anything else, I'm just a few minutes away. |
Posted: Sun Apr 27, 2008 9:13 pm Post subject: |
dale did you check on that bay window seat for sale on the craigslist?
$40 |
