Posted: Sat May 28, 2011 4:42 pm Post subject: Adjustable beam |
Hey all
I'm looking for someone who knows there way around installing beam adjusters on a split bus beam. I recently picked some up and want to throw them on my beam. Anyone who can help me with this task would be greatly appreciated.
Thanks Dan [/list] |
Posted: Sat May 28, 2011 5:10 pm Post subject: Adjustable beam |
Craig or Eric come to mind _________________ TROY
Posted: Sun May 29, 2011 5:05 pm Post subject: |
| Yeah they skipped my mind, I talked to Craig and were going to get it done |
Posted: Tue May 31, 2011 7:38 pm Post subject: |
| So I have my beam out and all taken apart, now I'm attempting to clean the grease out of the dang thing. Anyone out there done this before and have some suggestions for me on how to get the grease out? |
Posted: Tue May 31, 2011 8:55 pm Post subject: |
| Why do you want to take all the grease out? It is hard to remove it all, long rod with rags attached can pull it out. |
| Lots of rags!! |
Posted: Tue May 31, 2011 9:16 pm Post subject: |
Well Craig told me if I bring a clean beam he would help me put the adjusters in so I thought that meant cleaning out the grease. Also one of the bushings was kinda hanging out and the edge is broken. So I'm sure I need a new one.
Hey Eric I might need you to help me possibly if you have any time available if Craig can't cause he might be busy with another bus. I need this done soon for the Lind run woo hoo!! |
Posted: Wed Jun 01, 2011 7:26 am Post subject: |
| Well, let me know, I can probably get adjusters in my schedule. |
mikeyj007
Posted: Thu Jun 02, 2011 8:52 pm Post subject: |
If you're in the mood to work on suspension I'd love to get adjusters on the front of my Thing
and see about getting the back lifted as well. The last time we talked you mentioned tackling it
during the winter time. I'll make it worth your while if you're still interested. Let me know and
I'll order the parts.
Thanks in advance. |
Posted: Fri Jun 03, 2011 4:32 am Post subject: |
| I won't have time for a couple weeks, order up the parts. How high did you want to go? |
mikeyj007
moonsky1
Posted: Fri Jun 03, 2011 5:29 pm Post subject: |
Well Craig told me if I bring a clean beam he would help me put the adjusters in so I thought that meant cleaning out the grease. Also one of the bushings was kinda hanging out and the edge is broken. So I'm sure I need a new one. _________________ burberry bagsburberry handbagsburberry Shoulder Bags |
Posted: Wed Jun 08, 2011 9:09 am Post subject: |
| well i picked up my beam from eric on monday. i just got the new bushing all honed out to fit with my trailing arm, only took me a couple of hours using a brake hone. well im off to put it all back together and drop the bus a bit. |
