Problem solved, thanks Jim
PostPosted: Thu Sep 03, 2009 6:05 pm    Post subject: Problem solved, thanks Jim Reply with quote
One of mine is missing the spring, I know I can order one online, but if I can pick one up locally, it would be much better. #42 on the .pdf http://www.racetep.com/weber/40IDF70.pdf
amy
PostPosted: Fri Sep 04, 2009 6:53 am    Post subject: Reply with quote
I got one from the General Store. It's not specifically a return spring for a Weber, it's just a spring that's the right size, but it works fine. They have an aisle of springs and fasteners at the back of the store. The spring I got was less than a buck so I got 2.
PostPosted: Fri Sep 04, 2009 7:07 am    Post subject: Reply with quote
Thanks for the tip, I will go check that out today. Do you happen to remember which on it was? Just trying to save taking apart the other one, but it's not that big a deal.
PostPosted: Fri Sep 04, 2009 11:31 am    Post subject: Reply with quote
They didn't have anything in that was the right size, gonna try Lighthouse, and if they don't have it, a couple other hardware stores. Someone is bound to have a spring that is the same size, couple quick bends and done!
PostPosted: Fri Sep 04, 2009 11:56 am    Post subject: Reply with quote
I just looked, I do have one.
PostPosted: Fri Sep 04, 2009 2:10 pm    Post subject: Reply with quote
How would I go about acquiring this spring from you, if it's spare?
PostPosted: Fri Sep 04, 2009 3:42 pm    Post subject: Reply with quote
This weekend i'll be in and out, mostly out. Monday i'll be up on the road course at SCR all day if you want to swing by there, i'll throw it in my truck.
PostPosted: Fri Sep 04, 2009 3:44 pm    Post subject: Reply with quote
Not sure what SCR is? I have all day tomorrow and Sunday.
PostPosted: Fri Sep 04, 2009 3:58 pm    Post subject: Reply with quote
spokane county raceway
PostPosted: Fri Sep 04, 2009 4:02 pm    Post subject: Reply with quote
That makes too much sense.
