Narrowed Beam!
Kylees63
PostPosted: Mon Aug 06, 2007 10:40 pm    Post subject: Narrowed Beam! Reply with quote
Wanted: Narrowed Adj. Beam hopefully with dropped spindles, tho not necessary.
I'll trade some neat stuff or pay cash for for one. Might even pay to have it installed, I've already fixed everything else on the car and I'm a little tired of working on my days off!
Hit me up, I may have something you need, engines, engine stuff, Baja stuff.
Might be willing to trade enough to make 90%of a baja for install. Car, Motor, Baja kit, raised frontend, even a parts car.
No, not my kick ass baja, this one. Car and pan actually in very nice shape, was never made into a baja, just started.
PostPosted: Tue Aug 07, 2007 9:03 pm    Post subject: Reply with quote
If you end up not finding what you want in Spokane
hit up Franklins.
How narrow are you looking for? Is this for that blue 63?
Kylees63
PostPosted: Tue Aug 07, 2007 10:09 pm    Post subject: Reply with quote
Yeah for Izzy the bomb. Franklins just kinda too far away, and a little too pricey.
I was hoping someone around here would want to do it. Make my life easy and make themselves a little coin.
I may just order some CB's and see how much custom will put them in for, needs new pins which I have, I'm just kinda burnt.
PostPosted: Wed Aug 08, 2007 7:51 am    Post subject: Narrowed Beam! Reply with quote
Eric aka Longroofs does bus beams locally, I think he has done beetle beams, I'll check with him and let you know. If you only want to go 2", you can't beat the ones CB sells(under $200), all new one piece tubes, not cut and welded, has needle bearing for the arms instead of plastic bushings. Cameron at Volksfab builds a great beam too!
Kylees63
PostPosted: Wed Aug 08, 2007 7:54 pm    Post subject: Reply with quote
Yeah I've sent him a couple emails, may just have to go out there. He had alot going on last time I was there.
PostPosted: Thu Aug 09, 2007 9:12 pm    Post subject: Reply with quote
This Eric guy is in Newman lake right?
PostPosted: Tue Aug 14, 2007 7:50 am    Post subject: Reply with quote
not really hard to do one if you have a good welder. I just don't have time to dedicate to doning one or two a year. If there was more demand I'd tool up.
