		| Author | Message |
		| project_dog
				|  Posted: Tue Apr 22, 2014 1:45 am    Post subject: Hello everyone |   |
				| Hello everyone, Name is Brian, front Spokane, WA. I just picked up a 1967 Volkswagen Beetle. It has been about 10 plus years since I last owned a Volkswagen. My dad and mom had Volkswagen's when they grew up, from beetles, convertible beetle, baja bugs, fast back, bay window camper bus. I had a rag top baja bug, a split window kombie bus and now a 1967 beetle.  So Volkswagen's have been in my family. "Its not a hobby its a love affair."
 Anyways, I bought this 1967 last friday. My plan of attack is get the body off and redo the chassis, transmission, engine. Get some of the rust repaired on the car and i might just roll with the patina color.
 I would love to make it to one of the meetings, but I work nights at dealer ship.
 Well enjoy the pictures.
 IMG]http://i12.photobucket.com/albums/a225/Project_dog/1967%20bug/20140419_214913_zpso4ymkdhj.jpg[/IMG]
 I hope I can meet up with all soon.
		| Back to top |  |
		| ONEBADBUG
				|  Posted: Tue Apr 22, 2014 7:43 am    Post subject: |   |
				| May 7th is the next meeting, but if you go to Vintagevolks dot com, you'll see a discussion of some guys hitting the local car shows already. 67's have too many one year only parts to suit me, but then, I never leave anything stock!
 Steve
		| Back to top |  |
		| hubcapt
				|  Posted: Tue Apr 22, 2014 7:52 am    Post subject: |   |
				| Picked up Dustin's bug, looked like a solid project.
 I'd vote to keep the paint where its at, its only original once.
		| Back to top |  |
		| project_dog
				|  Posted: Tue Apr 22, 2014 1:58 pm    Post subject: |   |
				| Ill take a look at website. Thanks. |  |
		| Back to top |  |
		| Asesapie
				|  Posted: Tue Apr 22, 2014 7:32 pm    Post subject: |   |
				| Sweet bug man! Keep the paint as is, it's perfect! |  |
		| Back to top |  |
		| project_dog
				|  Posted: Thu Apr 24, 2014 11:12 pm    Post subject: |   |
				| Motor is almost torn down. I did a lot of cutting and hammering to remove the cylinders. But once I did. The crankshaft moved.  My question is can reuse the the 16 studs? It holds the cylinders liners and cylinder heads. |  |
		| Back to top |  |
		| Troy Hobbs
				|  Posted: Fri Apr 25, 2014 6:22 am    Post subject: Hello everyone |   |
				| Yes you can reuse them. Buff that up for now it will have some good patina, looks like it has been painted before though. _________________
		| Back to top |  |
		| sandals
				|  Posted: Fri Apr 25, 2014 7:06 pm    Post subject: Re: Hello everyone |   |
				|  	  | Troy Hobbs wrote: |  	  | Yes you can reuse them. Buff that up for now it will have some good patina, looks like it has been painted before though. |
 Yep. Overspray on the black box is a tell tale sign. Cool bug, though. Will look good on the road.
		| Back to top |  |
		| project_dog
				|  Posted: Sun Apr 27, 2014 12:36 am    Post subject: |   |
				| I cleaned up all the threads. They all look good. Some time this week I should be able to get the motor all torn down. I pulled the oil filter off. lots of water and some sort of sand in it.
 My question is can I pull the case apart with the piston still connected? Or someone could come over and help me? I live up North Spokane. I dont have much tools since most of mine are at the dealership. Right now the short block is at my work in liberty Lake
		| Back to top |  |
		| project_dog
				|  Posted: Tue Apr 29, 2014 11:54 pm    Post subject: |   |
				| Here are some more pictures. I got the motor torn down. It looks like the case is might be bad around the oil filter.
		| Back to top |  |
		| ONEBADBUG
				|  Posted: Wed Apr 30, 2014 8:03 am    Post subject: |   |
				| If it's an "H" block, probably not worth working on. But you could put it back together with as little money as possible, just for the experience. Then get a good engine later.
		| Back to top |  |
		| project_dog
				|  Posted: Wed Apr 30, 2014 8:33 am    Post subject: |   |
				| It is a H  block. Well ill be looking for a new engine. Are those h blocks made out of magnesium? |  |
		| Back to top |  |
		| project_dog
				|  Posted: Wed Apr 30, 2014 5:49 pm    Post subject: |   |
				| What kind of case should I buy. I either want to bore it out to a 1776cc or a 2110cc motor. I want to drive daily but also have fun at the drags. |  |
		| Back to top |  |
		| ONEBADBUG
				|  Posted: Thu May 01, 2014 4:22 pm    Post subject: |   |
				|  	  | project_dog wrote: |  	  | What kind of case should I buy. I either want to bore it out to a 1776cc or a 2110cc motor. I want to drive daily but also have fun at the drags. |
 That's everybody's dream! Unfortunately, the 2 are opposite ideals when building the engine.
 Back to your questions, they're all magnesium, but there's lots of different alloys. H is the worst, the head studs pull out quite commonly. You want a late model dual port block, like AE, AH, and the fuel injection cases are really good. AJ? I forget. I think Baxsie has one.
 Anyway, like I said, if you plan to do it yourself, build the one you have now for practice. I have bearings and stuff.
		| Back to top |  |
		| dssbk
				|  Posted: Thu May 15, 2014 11:42 am    Post subject: Engine case |   |
				| I wouldn't waste any time or money on that case, all that corrosion ain't gonna go away. I just creates weak points in the case and it will leak like a mutha f***er!!! _________________
 '62 Turbo Drag Bug
 '65 Street Custom Bug
		| Back to top |  |
