Timing question on my 1835cc
firebug
PostPosted: Sat Jun 29, 2013 9:44 am    Post subject: Timing question on my 1835cc Reply with quote
The engine in my bug was built by Bow Wow in Spokane back in the early 90's. It's an 1835cc and has dual weber 40's and a mild cam in it and I am wondering if anybody can tell me what I should be setting the timing at? Thanks
PostPosted: Sat Jun 29, 2013 11:15 am    Post subject: Timing question on my 1835cc Reply with quote
Would need to know what distributor you have to answer that question.
PostPosted: Sat Jun 29, 2013 4:12 pm    Post subject: Reply with quote
What Troy said...but, with a timing gun that has a degree wheel, set the total advance, around 3000 rpm, to 32-36 degrees. It depends on compression ratio, and the general use of the engine. A low compression engine can take as much as 42 degrees, a high compression engine might ping on regular gas with as little as 28.
Almost certainly you have a 009, so set the total, and then back it off if it's hard to start. Many 009's only have 20 degrees in them.
firebug
PostPosted: Sun Jun 30, 2013 8:34 am    Post subject: Reply with quote
It is the 009 distributor. We've started to try and dial it in but am still having flat spots when pushing it thru the gears. Sounds like 009's are notorious for that? Can it be dealt with or would it be better to put a vacuum advance distributor back in it? Thanks guys!
PostPosted: Sun Jun 30, 2013 3:58 pm    Post subject: Timing question on my 1835cc Reply with quote
The 009 flat spot is when used with a stock 34 pict 3 carb, dual carbs run just fine with them (may be better choices). Flat spots with dual carbs are usually from improper jetting, wrong float height, miss adjusted linkage or carbs just out of sync. Make sure your valves are set, check/set your point gap/dwell, and then time as Steve recommended. Then if you still have a flat spot, start checking the carbs.
