1200 40hp motor. $75.00
PostPosted: Wed Aug 22, 2012 6:20 am    Post subject: 1200 40hp motor. $75.00 Reply with quote
Have a 1200 that was good and tight in the end play but had a knocking noise to it. Was running when pulled and still turns by hand easily. Everything is there but the flywheel, distributor, carb and fuel pump. Good rebuild candidate. If interested call/text 509-280-8756
