Volkswagen newest key prog AK500 pro FAQ
quevag
PostPosted: Tue Aug 21, 2012 6:52 pm    Post subject: Volkswagen newest key prog AK500 pro FAQ Reply with quote
Q:Have AK500 pro car list?
A:AK500PRO Support Model:
Mercedes-Benz:
W220/W220“Keyless Go”W208/W210/W220/W203/W215/W230/W209/W219/W211/W230/W215/w164
BMW:1/3/5/6/7/8/ :
MPC(MPC555/556,MPC561/562,MPC563/564),external Flash(MB58BW016,29BL802C,AM29BDD160,S29CD016,DE28F800 etc.) and external EEPROM(M95xxx)
Volkswagen
Audi:MPC(MPC555/556,MPC561/562,MPC563/564),external Flash(MB58BW016,29BL802C,AM29BDD160,S29CD016,DE28F800 etc.) and external EEPROM(M95xxx)
Q:How AK500PRO select key?
A:Mercedes Benz KELESS GO contains two styles: old style with black edge and new style with electroplating edge
1, when use new style key with electroplating edge to process KEYLESS GO, if original key is with black edge, then keyless go key must be with black edge( the key must be fully-new blank or has been refreshed to blank, and remote control frequency must be as same as original key frequency.)
2,if original key is with electroplating edge, then KEYLESS GO key must be with same electroplating edge (the key also must be fully-new blank or has been refreshed to blank, don't use old style KEYLESS GO key with black edge,otherwise it will not support KEYLESS GO function.)
______________
AK500 PRO
don't worry!be happy.
quevag
PostPosted: Sun Aug 26, 2012 7:06 pm    Post subject: Chapter two: Why would a verify engine light be on? Reply with quote
The verify engine light comes on and stays on when a problem is detected by the self diagnosis program of one's car. Commonly, the issue is inside the emissions or something that is definitely affecting the effectiveness from the emissions, but other causes can trigger the light to come on, also. To ascertain the result in, the automobile will must be taken to AutoZone or perhaps a shop that has an OBD2 scanner, or for 1995 and earlier models, an OBD1 scanner, Whilst a scanner will not provide you with the magic answer, it'll provide you with a code that narrows down the problem spot.
A flashing examine engine light is an indication of a severe misfire or dilemma that's most likely to harm your engine. Quick diagnosis and service is required.
Some particular causes for the light to be on are:
Gas cap left off, not tightened, not installed appropriately, or wants to become replaced.
02 sensor.
Engine misfire - error may well clear itself following three complete warm-up cycles; not restarts, but warm-ups.
At start off up to get a bulb examine - Shouldn't stay on.
Difficulty in the emission technique, which includes clogged exhaust or the catalytic converter not functioning properly:
Dirty/clogged air filter.
Dirty MAF sensor.
You will discover pages and pages of items which can cause a verify engine light to come on. Obtaining it checked having a scan tool will narrow down the issue area.
More details technical support on http://www.chinasinoy.com
