Posted: Sat Sep 01, 2012 10:35 am Post subject: |
Your VW is designed to run at 3200-3600 RPM for extended periods of time. That is how they were engineered. They are not like a modern car that cruises at 2500 RPM at 70 MPH.
I like to drive my bus at @ 60-63 MPH. That seems to be it's happy place. |
Posted: Sat Sep 01, 2012 11:03 am Post subject: |
If we travel at 50 MPH I think it will be ok, but it will be a long ride. _________________ '62 Turbo Drag Bug
'65 Street Custom Bug |
Posted: Sat Sep 01, 2012 11:46 am Post subject: |
What engine/tranny/tire size are you running that you can only go 50MPH? |
Posted: Sat Sep 01, 2012 8:33 pm Post subject: |
Engine Size.....2007cc
Trans.....4.37 R&P stock 3rd & 4th
Rear Tires.....205/40-17
I'm not exactly sure on the speed, but my engine screams if I try to keep up with traffic.
I'll try again this weekend with my GPS so I can see how fast I'm actually going. _________________ '62 Turbo Drag Bug
Posted: Sat Sep 01, 2012 8:36 pm Post subject: |
Do you have a tach? Maybe what is perceived as screaming is just a loud exhaust and 3000 RPM. It would be a bummer to have that big engine and only be able to drive 50 down the highway. |
Posted: Sat Sep 01, 2012 8:45 pm Post subject: |
Yes, I have a tach and it is loud in my car. The straight cut gears, 48 IDA's and Phat Boy exhaust probably make it sound worse than it is. _________________ '62 Turbo Drag Bug
Posted: Sat Sep 01, 2012 9:01 pm Post subject: |
Sounds like ear plugs are in order. |
Posted: Sat Sep 01, 2012 9:15 pm Post subject: |
Maybe I'll just turn up the sounds..... _________________ '62 Turbo Drag Bug
Posted: Sun Sep 02, 2012 2:23 pm Post subject: Just Curious |
dssbk wrote: | ...straight cut gears, 48 IDA's... |
What are the rest of the specs on your engine? _________________ Jeff Rogers
9.35 @ 145 |
Posted: Sat Sep 08, 2012 4:58 pm Post subject: |
I have decided to drive the Bug to Yakima...does anyone have an idea of what time the caravan will be leaving Spokane? Also, what route will be taken? Thanks...Dale _________________ '62 Turbo Drag Bug
Posted: Sat Sep 08, 2012 5:36 pm Post subject: |
Not sure of departure time or route yet. One of the crew will let you know when we know. |
Posted: Mon Sep 10, 2012 7:08 am Post subject: |
How about a 10am takeoff from the top of sunset hill, the Medical Lake exit with the truck stop? I would have to look up the exit number, but how does that sound? |
Posted: Mon Sep 10, 2012 8:25 am Post subject: |
I believe its Exit 272 _________________ '62 Turbo Drag Bug
williamalan
Posted: Mon Sep 10, 2012 9:01 am Post subject: |
Sounds great. Do we know the route yet?
Also the flathead run is this weekend. |
Posted: Mon Sep 10, 2012 10:27 am Post subject: |
Sounds great to me. Supposed to be much cooler this year, so we likely won't see 100 degree temps at the Lucky Leprechaun in Othello this time. |
