88mm rings
PostPosted: Mon Feb 13, 2012 11:28 am    Post subject: 88mm rings Reply with quote
Need a 3mm wide compression ring (second ring) for a 88mm type 1 big bore piston set. Will consider whole set, set for one piston or even a used ring, only need the one so let me know what you have. These are Vicsa 88mm pistons, made in Brazil and have 2mm 3mm 5mm ring grooves.
