Split Bus RGB Stub Axle****Found One****
ekimikem
PostPosted: Fri Nov 25, 2011 8:08 pm    Post subject: Split Bus RGB Stub Axle****Found One**** Reply with quote
Looking for a big nut 24 tooth rgb stub axle for a 67 bus transmission. I think they may be the same '64-67 but not for certain. The difference would be in the tooth count. I'm also looking for some brake backing plates for a 67 bus trans. These would also be the same '64-67.
PostPosted: Sat Nov 26, 2011 1:32 pm    Post subject: Re: Split Bus RGB Stub Axle Reply with quote
Contact Corey, he was here yesterday, said he has a parts trans for you.
ekimikem
PostPosted: Sat Nov 26, 2011 7:38 pm    Post subject: Reply with quote
Thanks Eric, don't know why I didn't ask him in the first place. Still working on getting down your direction one of these days.
