Joined: 13 Oct 2009 Posts: 185 Location: Spokane 5-mile
Posted: Sat Oct 22, 2011 6:49 pm Post subject: Front Beam Jig |
Stole this idea from Eric, I hope you don't mind
Had some scrap metal and some free time. Not necessary but
it will make narrowing my beam easier!
Posted: Sun Oct 23, 2011 8:07 am Post subject: |
| Nice, that will work! When welding, take out the outer bushings/bearings. |
Posted: Sun Oct 23, 2011 8:27 am Post subject: |
Thanks.
Thanks for that tip. Probably would have forgot and had to buy some new ones!
I still need to put in some center torsion "locaters" like yours has.
Been busy building a deck so it was nice to get a little time. |
klokwerk
Posted: Wed Oct 26, 2011 11:07 am Post subject: |
This looks awesome!
Just got my 67 and I've been looking into a narrowed beam.
How difficult is it to do it yourself? _________________ '67 Bug, '89 GTI |
Posted: Wed Oct 26, 2011 11:24 am Post subject: |
Thanks klokwerk,
The idea is real straight forward.
This is my 1st beam and has been relatively easy. I ran into a couple issues but got through them.
Couple guys on the site have done beams (Eric for one) and are more than willing to give some advice.
Any questions or concerns, feel free to post them! |
Posted: Wed Oct 26, 2011 2:49 pm Post subject: Front Beam Jig |
Duke's jig is for a bus beam, beetle is a whole different animal _________________ TROY
klokwerk
Posted: Fri Oct 28, 2011 4:22 pm Post subject: |
Thanks Troy. I realized that after. But wouldn't a similar jig for a bug look the same? _________________ '67 Bug, '89 GTI |
Posted: Sat Oct 29, 2011 3:05 pm Post subject: Front Beam Jig |
not really, the bus bolts on with the end plates, a beetle bolts to the frame head in the middle off the tubes _________________ TROY
Posted: Sat Oct 29, 2011 5:26 pm Post subject: |
Hey klokwerk,
Are you replacing the end plates or are you just welding in some adjusters?
If you replace the end plates, just punch out the bearings, cut your beam to whatever length you want it, weld your plates on, and install some urethane bushings in place of the bearings.
If you are just welding in adjusters , make sure you cut one tube at a time or you will have trouble lining it back up. (I use angle iron and c-clamps to line up the tube and adjuster prior to welding) Good Luck!!! _________________ '62 Turbo Drag Bug
'65 Street Custom Bug |
klokwerk
Posted: Mon Oct 31, 2011 12:48 pm Post subject: |
I'm still learning how the front end works.
To be honest, I don't know what I'm doing just yet.
Thanks for the tips. I'll be sure to keep it in mind. _________________ '67 Bug, '89 GTI |
Posted: Tue Nov 01, 2011 8:06 pm Post subject: |
Had some time today to do a little work on the beam.
Built a "locator" for the adjuster bolts. This will ensure that I get the correct angle on the adjusters. Luckily it will work with the adjusters installed. Didn't think about it until after I welded the adjusters in.
Decided to go with new steel for the tubes. Got some 2" SCH 40 pipe.
Drilled some holes for placement of the adjusters
Cut out the steel, ready for adjusters
Adjusters welded in.
Posted: Tue Nov 01, 2011 9:22 pm Post subject: |
Those are upside down!!!
just kidding!
Posted: Wed Nov 02, 2011 8:51 am Post subject: |
Great. Upside down!! Now I gotta start all over!  |
Posted: Wed Nov 02, 2011 6:25 pm Post subject: |
Put it together
Was able to put it in the bus to make sure it fit. It fit great!!
Posted: Wed Nov 02, 2011 6:41 pm Post subject: |
Damn Duke...that beam looks STOUT! Where did you get the ends done, same place as Eric? You know, eventually, you're gonna have to stop fabricating, and start driving that sucka!!! Looks GREAT!
