Fuel cut off valve for type 3
PostPosted: Wed Jun 15, 2011 4:18 pm    Post subject: Fuel cut off valve for type 3 Reply with quote
Well the title says it all, I'm looking for a fuel cut off valve for type 3 that is in good working order. The type that goes in line between the carbs and fuel pump.
Thanks Dan
PostPosted: Wed Jun 15, 2011 8:05 pm    Post subject: Reply with quote
Dan, do the type 3's use a special valve...or can you just use a brass "T" fitting? If the fitting is all you need, I just got a really nice heavy brass one at the General store in their hardware dept for $5.
PostPosted: Wed Jun 15, 2011 8:27 pm    Post subject: Reply with quote
Well the thing is I need the cut off valve cause my carbs don't have the cut off solenoid and my carbs leak occasionally so i need the cut off valve to help prevent that from happening anymore. I've tried just about everything else
