Rotisserie
Goto page 1, 2  Next
PostPosted: Wed Dec 22, 2010 5:52 pm    Post subject: Rotisserie Reply with quote
Just started building my rotisserie. Thought I might throw a couple pics on here and see what you think.
Built out of mostly 2.5"x2.5" square tube 3/16" thick
Here is what I got done today.
PostPosted: Thu Dec 23, 2010 9:08 am    Post subject: Reply with quote
My buddy who has one used spindles and brake drums for the rotation point, then he built a lever that would work the parking brake. my concern with your application is: If you bolt it to the bumper points on your bus, it won't be anywhere near the polar moment. I guess you could make an "adapter".
PostPosted: Thu Dec 23, 2010 10:31 am    Post subject: Reply with quote
It is going to be completely adjustable and I am going to use hydraulic jacks to raise and lower the "hangers". I am going to mount to the beam mounting points. There won't be any issues in getting it completely balanced.
I still have a lot of work to do on it.
PostPosted: Sat Dec 25, 2010 1:58 pm    Post subject: Reply with quote
That will be nice when finished those make metal work a breeze!
PostPosted: Sat Dec 25, 2010 2:03 pm    Post subject: Reply with quote
Thanks vwrus66. I dont have a lot of metal work to do on the bus, but is will sure be nice when cleaning it up and painting the bottom. It will also be nice on future projects!
PostPosted: Wed Dec 29, 2010 12:04 am    Post subject: Reply with quote
Little more progress.
Couple pics. Still a little more work. Gussets, Jacks, casters and arms left.
Getting close!
PostPosted: Wed Dec 29, 2010 8:56 pm    Post subject: Reply with quote
Got a couple minutes today and built the caster plates and installed the casters.
6" casters, 2" wide. 1000 LBS Load capacity each. Greasable caster and wheel axle.
PostPosted: Thu Dec 30, 2010 12:50 pm    Post subject: Reply with quote
Finished installing the wheels on both ends.
Now just have to make some gussets and arms.
PostPosted: Fri Sep 30, 2011 4:34 pm    Post subject: Reply with quote
With the wifey's home improvement projects, my garage time is at a premium. Got some work done on the rotisserie, though!! Almost done, just a couple little things. Hopefully get the bus up soon.
PostPosted: Sat Oct 01, 2011 8:04 pm    Post subject: Reply with quote
Damn Duke! That thing is really coming together!! Are you working off a blueprint, or just fabbing it as you go? I noticed the carpenter chop saw in the background with an abrasive cut-off wheel on it. How good is that working for you?? I'd like to try that instead of buying yet ANOTHER tool!
Definately put me down for the first in line for Rotissere Rental!!! Laughing Looks great!!
PostPosted: Sat Oct 01, 2011 8:29 pm    Post subject: Reply with quote
Scott,
I have some plans, but "modified" them a bit. I kept the adjustability for use on other types of cars.
The chop saw works pretty good. Sometimes when cutting large, thick steel it can veer off a bit.
Dropped the front beam today and test fit the front! Very Happy Everything matched up as planned.
PostPosted: Sun Oct 02, 2011 8:46 am    Post subject: Reply with quote
Looks good! I know I'd want a few people around before the first "flip" took place!!! Just in case, you know? Shocked
PostPosted: Mon Oct 03, 2011 7:26 am    Post subject: Reply with quote
Nice Duke.
PostPosted: Mon Oct 03, 2011 8:51 pm    Post subject: Reply with quote
Thanks guys. Had a chance yesterday to do a bit of work. Pulled the engine, trans., and fuel tank. Installed the rear rotisserie arms. They attach to the rear torsion housing. I also fabbed up a bracket to connect to the trans. cradle for added support.
PostPosted: Tue Oct 04, 2011 6:33 pm    Post subject: Reply with quote
Sorry for the crappy pics. Cell phone pics and it was getting dark!!
Goto page 1, 2  Next
Page 1 of 2
