Small inlet DP intake center or Large throat PICT carb
SprÝ Norsk
PostPosted: Mon Feb 15, 2010 5:37 pm    Post subject: Small inlet DP intake center or Large throat PICT carb Reply with quote
The intake I have now is for the larger 34 PICT carbs and I am thinking I would like to run a 30/31 I have. I will gladly trade my larger intake for your smaller one. I am also willing to pay a little cash for one. I would also consider a cheap good carb that will work with my large DP intake center. Let me know what you have.
PostPosted: Mon Feb 15, 2010 5:49 pm    Post subject: Re: Small inlet DP intake center or Large throat PICT carb Reply with quote
I just sold a DP/small carb. intake on The Samba a couple weeks ago, I think I still have another....will look tomorrow.
PostPosted: Mon Feb 15, 2010 6:15 pm    Post subject: Small inlet DP intake center or Large throat PICT carb Reply with quote
I have one if you still need one. TROY 993-1981
PostPosted: Tue Feb 16, 2010 3:57 pm    Post subject: Reply with quote
I have one too, clear heat riser, heat riser has some pitting though. Troy's may be better.
SprÝ Norsk
PostPosted: Wed Feb 17, 2010 9:50 am    Post subject: Reply with quote
How much do you guys want for it?
PostPosted: Wed Feb 17, 2010 12:04 pm    Post subject: Reply with quote
I'll take $30 for mine.
PostPosted: Wed Feb 17, 2010 3:55 pm    Post subject: Small inlet DP intake center or Large throat PICT carb Reply with quote
Call me
