Posted: Sun Jan 16, 2011 11:22 am Post subject: |
I am about to start again on my sea blue 65 beetle. I am contemplating whether to replace the rear bumper brackets, as they are in rough shape. But I have many more issues to deal with on this car than to worry about bumper mounts. By the time I finish the rest of the rust repair, I may just look the other way when thinking about bumper mounts. |
Posted: Sun Jan 16, 2011 8:49 pm Post subject: |
yea, the mounts will be a bit more of a pain than I first expected, but it will be worth it.
I remember seeing yours Corey (5 feet up in the air) and with the rust repair your tackling Id probably be drinking more , that looked rough! |
Posted: Sun Jan 16, 2011 11:33 pm Post subject: |
My 65 will have more time into than it is worth, but it is teaching me how to do rust repair/welding so that when I tackle a bus, I won't be a virgin. |
Posted: Mon Jan 17, 2011 8:25 am Post subject: |
I got a little free time this weekend to do some work on the bus. Finished the front brakes, pulled the engine back out to install new heads. Found #3 piston had been burned from detonation/heat on bottom side. Weird, because this engine had great compression and ran great (after I tapped #3 spark plug and installed heli-coil). So....apart she comes. I'm hoping this will be an easy rebuild with little to no machine work needed. Just going to go stock with this engine, I want to drive it this spring!!!!
Posted: Mon Jan 17, 2011 9:07 am Post subject: |
well i put about 3 more hours into the bus this weekend and got a bit more sanding done and all the windows out now except the windshields.
Orange
Joined: 25 Aug 2009 Posts: 43 Location: Spokane Valley
Posted: Mon Jan 17, 2011 9:21 am Post subject: |
You look like you have a good start! |
Posted: Mon Jan 17, 2011 11:58 am Post subject: |
looking good everyone. |
Posted: Mon Jan 17, 2011 4:15 pm Post subject: website working?? |
I posted earlier today....nothing showing yet....maybe website is down?
Posted: Tue Jan 18, 2011 5:51 pm Post subject: |
I like the marblege Dano!
Picked up a new bottle of gas for the welder, ran out making shelfs in my garage out of bed frame rails (angle iron costs too much, why not recycle?). They messed up and sent me home with a copy of a reciept that they needed for their files, said if I was able to return the reciept before 5pm my next fill would be free.... SHWINGGG!!!! Should get those brackets fitted and welded soon. |
Posted: Sun Jan 23, 2011 11:26 am Post subject: |
here is what i have got done today so far on the sanding
Vails74beetle
Posted: Sun Jan 23, 2011 12:51 pm Post subject: |
I spent most of the night grinding the floorpans in side and out. I cant feel my arms today sure glad football is on. |
Posted: Tue Jan 25, 2011 6:52 pm Post subject: |
after spending a lot of time studying wiring diagrams I decided to rewire my bug. Have the wire laid out and started to hook things back up.
hopefully I have it done in another day or 2 then I can drive it again. _________________ hakunamatata |
Posted: Tue Jan 25, 2011 10:15 pm Post subject: |
Tackling a huge wiring project sounds like a pain, but what you will learn from it will save you $$$ down the road, plus it will get you off the side of the road! |
Posted: Wed Jan 26, 2011 5:25 am Post subject: |
That is so true hub. I rerouted the wires to the rear through the baggage compartment and along the right side of the tunnel. No wires running along th outside of the car. I have tio keep switching from stock diagram to the chrico one. But, it's coming together nicely. the BIG plus for me is I won't have a rats nest under mt trunk lid. _________________ hakunamatata |
Posted: Thu Jan 27, 2011 5:40 pm Post subject: |
well everything below the roof is done being rough sanded. next finish the roof and start to smooth sand everything, then prime and paint. i wish i had a sandblaster though man that would be fast haha |
