Motelcambodia
Joined: 14 Sep 2009 Posts: 34 Location: Idaho/Cambodia
Posted: Sun Feb 21, 2010 5:34 pm Post subject: |
I'm Back from Asia , its nice here no snow and not too cold.
Today Put in my new distributer with the no points electronic thing. Works nice . But I will keep my old points distributer in the baja just incase this new one craps out.
Brian _________________ Work In Idaho Live in cambodia |
Posted: Tue Feb 23, 2010 9:27 pm Post subject: |
Well with the mango tucked safely in the garage until it sells there isnt so much room to fidle with the single cab. But have found og paint doors, decklid and a crusty funky emblem for it. Other projects are getting closer to the burner.
Also might be picking up a 63 Riviera..... more to come, once its home |
Posted: Sun Feb 28, 2010 10:39 pm Post subject: |
Well, finally got around to putting pans in our 70' bug...what a mess. As soon as I started pulling carpet out it didn't look good. Pans were trashed, I already knew that...but the heater channels need replacing too. Soooo...I checked out our 68' bug that needs pans also. Looks like the channels are pretty good in that one. Restoration plans changed...now I'll be fixing up the 68' and not the 70! Pretty soon I'll probably have a 70' for sale that's prepped for pans!
Posted: Wed Mar 03, 2010 12:59 pm Post subject: |
Picked up my parts from a Montucky Dealer yesterday and ooeee-La-La!!! The single cab is going to be back in business!!! |
traderj
Posted: Fri Mar 05, 2010 7:46 pm Post subject: |
Scott you should turn that 70 into a Baja. Take some ques from the dune buggiers and use some 1x2 square tube and diamond plating for the pans. Came close to doing that with my 66. But it's too good of a year for that.
As for me. I got some cash in. So I'll be doing pans and channels here soon. Have to find a place that has them in stock first.
But it feels like spring now. So not really a "winter" project |
Posted: Fri Mar 05, 2010 10:42 pm Post subject: |
Hey Jordan.....she really wants a Slammed bug for her daily driver, not much luck in convincing her! As soon as we get the title back from DMV, we're gonna put it up for sale. Might haul it down to the Bugfair this year for sale, along with alot of other parts that have found their way home with me!!
(Check with CIP, they had heater channels and pans in stock last Sat when we were price checking!!) |
Posted: Thu Mar 11, 2010 10:58 am Post subject: |
Started pulling pan bolts off my 72 baja and ended up breaking 4 of them off the passenger side the pics are in my gallery I figured out how to post them on the samba but haven't firgured it out for here. _________________ hakunamatata |
Motelcambodia
Posted: Thu Mar 11, 2010 11:29 am Post subject: |
Going to build a new motor for my Baja as the one in it had over a 1/8" end play.
This will be my first VW motor I ever rebuilt I have my donor motor all apart and going to have it checked out and maybe opened up to 1780cc? with a eagle 110 cam , I still want to run the signal carb a 34 somthing . and my 1/2" trimil header
I will do this in my 12X8 shop behind my house
I need to get me trans axle rebuilt too It leaking and making noise.
Posted: Thu Mar 11, 2010 11:33 am Post subject: |
Hey hotel there are at least 2 buses at pick-n-pull on north market. I'm tossing around the Idea of putting a bus tranny in my bug along with gear reduction hubs. _________________ hakunamatata |
Motelcambodia
Posted: Thu Mar 11, 2010 6:13 pm Post subject: |
bugpack wrote: | Hey hotel there are at least 2 buses at pick-n-pull on north market. I'm tossing around the Idea of putting a bus tranny in my bug along with gear reduction hubs. |
I like the idea of a bus tranny but not reduction ,
I may have to go look.
Posted: Thu Mar 11, 2010 7:06 pm Post subject: |
Brian, Let me know in advance and I'll roll with ya. like a week in advance. have to check my allowance ya know.
Dale _________________ hakunamatata |
Posted: Thu Mar 11, 2010 8:42 pm Post subject: Winter Projects |
In the last couple weeks I've gotten quite a bit done.
Put the Thing drums and type 3 wheel cyl's on the back of the Micro. Also installed the hitch and light pigtail and adjusted the valves and installed a fuel cut off solonoid on it. Still need to change the oil.
Put the engine in the race car, swaped the beam, installed front and rear sway bars, front and rear shocks, longer rear press in wheel studs and set the ride height. Now needs an alignment, valve and carb check and oil change all before the 20th. _________________ TROY
Posted: Thu Mar 11, 2010 10:06 pm Post subject: Street Bug |
Well, I have been working on two projects. I will start with the street bug first.
I am almost done with my new 2110cc street engine. It has been 6 years since I had a real engine in my street bug. If all goes well I will put it in this weekend and then get a good tune on it.
Just for a comparison, I did a dyno pull today to see how wimpy my tired stock 1600cc is. I put down a wopping 35hp and 53 ft/lbs of torque to the ground! I am sure the new engine will be a little better. _________________ Jeff Rogers
9.35 @ 145 |
Posted: Thu Mar 11, 2010 10:11 pm Post subject: Race Bug |
My second, but slow coming project is the continuation of trying to complete my race bug.
I should be able to get it out this season..... finally!
Here is some info on the project...
http://www.badbug.com/pantera_efi.htm
Other than tuning the engine a bit more and hooking the nitrous back up, I need to finish building the new transaxle and updating my safety gear. Then I should be ready to lay down some runs.
9.35 @ 145 |
Posted: Sun Mar 14, 2010 10:12 am Post subject: |
Just found this thread. Over the winter I have been working on rust repair on my 65 beetle. I pulled the body off the chassis and repaired/replaced both pan halves. The front 3/4 of each side was replaced with OG metal from a donor car. The battery tray was repaired with new aftermarket metal. The aftermarket stuff really sucks, bad. I would have been better of making one from scratch.
Yesterday I finished de-greasing the tranny, and will replace all the seals and gaskets to make it leak free. Then maybe a round of black paint to freshen things up.
Next I will finish welding the pan and hit it with Ospho and some paint, and seam sealer. Then on to rust repair on the body. Heater channels are OK, but there are various rust holes in several places. I have the bottom six inches of another bug to provide donor metal. Cut, weld, grind.
This is my first foray into rust repair and welding at this level. I am learning a lot, and I have new respect for those who do this type of thing everyday. Since I am not doing this for a living, I can swear and smash things with a hammer when I get frustrated, then walk away and go have a beer and watch a hockey game. It'll still be there tomorrow, and the only customer to complain is me. |
